Ocasional very long lines
Just now and again some Forum threads have very long lines and I need to scroll(?) sideways to read. Does anyone else get this? Is there a fix?
TIA
Fixes: 5
I think this is usually because someone has posted an image that is wider than the normal forums width, so it causes the page to be pushed out to that width. As far as I know there isn't a fix for it, other than for people to not link to such big images!!!
Phil
This is normaly caused by wide images or very long links posted.
We normaly correct both where possible. However, I find the hard to spot, due to my monitor settings.
how do u fix it?
By editing the post to make long urls into links if possible.
