OUTLOOK EXPRESS
OUTLOOK EXPRESS
Hello Folks
Not 100% sure if this is the place to post this
Have outlook express but have a problem with the spell checker
It dont work and is greyed out
been onto the company that sold me the pc but they are of no help what so ever
not very good at the pc stuff so can someone tell me how to get the spell checker to work in plain english
I would be very very greatfull
rja66
OUTLOOK EXPRESS
Hi. I dont think OE has a spellchecker of its own as such but appears in OE when you Install Microsoft Word either as part of Ms Office or MS Works.
If you have it installed you could try a repair by following the instructions here: http://www.theeldergeek.com/oe_spellcheck.htm
Hope this helps.
OUTLOOK EXPRESS
Hello
Thanks for the reply and the link
My pc did not come with an xp disk had to make a sort of recovery disk when first turned on
got a word disk but that dont help in any way
guess il have to use a paper book and work alot more on spelling
thanks for your help
rja66
OUTLOOK EXPRESS
You could try a stand alone spell checker for OE.
You can download one from here: http://www.geocities.com/vampirefo/
Alecto
OUTLOOK EXPRESS
If you install Microsoft Word, then OE automatically picks up the spellchecker dictionary from there.
And check in OE under Tools Options Spelling that you've ticked the box telling it to check the spelling.
Try uninstalling Word and putting it in again. It shouldn't need any action from you to make it work.
Fixes: 57
OUTLOOK EXPRESS
There is another problem.
If you have Outlook Express running under Windows XP and an earlier version of word (97 for example) then a dll can be missing.
If this is the case find a copy of the file csapi3t1.dll and place it in the folder "Program Files\Common Files\Microsoft Shared\Proof".
