Nokia 3650 and Plusnet Mail
Anyone know how to configure the Nokia 3650 to plusnet mail ??
Or even has anyone got this working firstly ?
Thanks Ivan
Do you mean dialling up using your Nokia (and then accessing your email)?
This should simply be a case of creating a dialup connection on your PC and selecting the Nokia as the modem.
I presume the poster is reffering to using the e-mail client on the phone.
Thomas
Sorry yes I mean using my phone to access the plusnet mail and not using my phone as a modem. I have seen this done on a tiscilli account
http://www.filesaveas.com/3650connect.html
But I need to know the dialup number etc based on this.
Thanks Ivan
Most of the settings are the same as that page, only you change server names, the dial-number and the name of the account.
If you have DSL on your current PlusNet account, your best bet is to signup for a new pay-as-you-go account with PlusNet. Allthough the dialup username will be different, you can still collect and sent e-mail from your normal address.
This will stop any problems with your connection dieing while you check your e-mail.
Based on the layout of that page, you should use the following settings instead. You can keep to the step by step guide and picture they then give.
Connection name: PlusNet
Data bearer: GSM
Phone number: 0845 140 0101 - Alternate number: 0870 7063000
Username: Either your current one (before any @ sign) or the new one if signing up for PAYG
Password: Your connection password
Password prompt: No
Authentication: Normal
Gateway IP: 0.0.0.0
Data type: ISDN V110
Maximum data speed: 9660
For the e-mail settings section
Mailbox name: PlusNet
Access point in use: PlusNet
My e-mail address: Your choice
General tab internet access: PlusNet
Outgoing mailserver: relay.plus.net
Username: username as noted in dial section, or the username fot he mailbox you wish to use
Password: Mailbox password
Incoming mail server: mail.plus.net
Mailbox type: POP3
Security: off
APOP Secure login: off
Thanks Phill I do have an ADSL account BTW.
Great just got it working.
You have to setup a new carrier for Vodafone GSM on the Nokia 3650. Done this and it worked first time.
Cheers.
