New style DSL Modem supplied by Plus.
I have just assisted a friend to get onto Broadband. The modem supplied was not the USB one I expected but a network connection modem that stores username and DSL password. It remembers this data even when unpowered, as in a power cut situation, so there is no need to reload the data. (checked that as the person would have no idea how to do it and would be phoning me if there was a power cut) What I did not do was make a note of the model - no use phoning him - and I am sure it was a Voyager but cannot find anything on the Net. Would somebody advise what it is please and can you buy them so a few other people can stop dialing in every time they switch their computers on? Thanks.
fakesnake
hi are you sure it is a modem, and not a router.
if your friend got their modem / router from + Net, it could possibly be one of these models - http://www.plus.net/support/broadband/hardware/index.shtml
Modem / Router
Yes, thank you. It is the Voyager 210. Now for the second question; can they be bought from Plus or elsewhere?
Fixes: 57
Voyager 210
Thank you. Will wait a bit and see what the prices on eBay will be. Not searched yet. Don't want it to be too expensive as I am just looking for two friends who are on the DSL modem that has to be dialed each time the computer is switched on. Both on Plus Net.
Fixes: 57
If you want cheap - try their associate company which has B grade with a 30 day warranty
http://www.dsldepot.co.uk/index.asp?
The Speedtouch routers are highly recommended
Cheap - used - modem routers, etc
Thank you for the link; that might be useful in the future. None of this particular item yet though. No rush as the people I am researching this for don't know about it.
