New Drive
morgan2476
New Drive
I have a new drive and I would like to copy my old hd onto the new (including the partitions). The problem is that the likes of powerquest drive image will only copy one partition. any ideas?
New Drive
You need something like Norton Ghost which would do the job.
New Drive
The best is the new version 10 of Acronis true image from
http://www.acronis.com/homecomputing/products/trueimage/
The new version lets you copy the drive and then setup backups as image sor just backup you email or files and it also lets you have a emergency restore by pressing F11
or if you want a free copier http://www.miray.de/products/sat.hdclone.html#info
morgan2476
New Drive
the likes of norton ghost seems only to copy 1 partition, i was looking for something that will copy the 3 partitions and files and settings on to the new drive.
New Drive
Ghost gives the option to copy partitions or full disks iirc.
New Drive
Yep it will copy ALL of the partitions onto a new disk of equal, larger or even smaller sizes. Cheesy
New Drive
Im surprised drive image does not do the whole disk, afterall that is what its name implies.
Last time I used it (a few versions ago) it was designed to copy everything, including multiple partions from one drive to another.
I suggest you read up on its use as it should do what you want.
morgan2476
New Drive
Yep thanks folks i now see how to do it - i assume that the partitions will be resized proportionaly on the new drive?
New Drive
They will with Norton Ghost but I cant speak for Drive Image as I have never used it.
holdtight
New Drive
Trueimage will also do the same as ghost but as John says not tried the others so cant comment
