Networking
Networking
I have just set up a wireless network at home for my two desktop PC's using a Belkin ADSL model with a built-in wireless router and a Belkin wireless desktop netwirk card. I can access the internet on both PC's but I am struggling to set up the network so both PC's can see each others hard drives and share a printer etc. I have followe (well think I have) the home network wizard in Window XP on both PC's. Any suggestions or good tutorial websites would be appreciated.
Many Thanks
David
1 REPLY
Networking
www.buzzons.co.uk/tutorials/network/network.htm
its about 3meg so will take a while to load if you dont have a fast line.
there may be some differeneces in here as this is for a wired network, but I am going to assume that its basicaly the same.
Also, if you are running SP2 make sure the firewall is off, and that simple file sharing (Tools -> folder options -> views) is turned off.
Buz
