Networking my desktop and laptop via wireless cards
StuWard
Using my Voyager modem, i would like to network my desktop to my Dell Laptop.
Desktop has a linksys wireless card and Laptop has a Wireless WLAN card
I know nothing about networking but would like to access the internet via my laptop wirelessly
Could somebody give me some advice on how to do so. I believe i have all the kit in order to do it, but i don't know what settings to use.
OS on desktop is Win XP and Laptop is Win 2000
Stu
Set your desktop pc to have an ip of 10.0.0.2 with a subnett 0f 255.255.255.0 and set up the dns to plus nets dns.
Set the laptop to have an ip of 10.0.0.1 with a subnet of 255.255.255.0 and set plus net dns again but on this one set the default gateway as 10.0.0.2
It should now work but depending on the network cards you may have to seek the other pc out there is normally a util with the card to do this. You may also need to set the card to add hoc mode.
StuWard
Is this setting the desktop wireless card ip ?
If its the PC itself, could you tell me how to do that ?
As i said i'm a total beginner
StuWard
hey buzzons thanks for that mate, can't quite work out the file sharing bit at the end though
Stu
its just to disable the simple file sharing and then shows how you can do it the proper way
StuWard
I disabled simple file share on my xp pc but i can't find the same tick box on win 2000
Also tried the //ip/drive$ in win exp but it would not connect
Stu
Stu
try \\ip\drive$ - that oughtta work
or if you know the hostname of the machine you're trying to connect to \\host\drive$
StuWard
got it sort of working now, but i get a popup box asking for a user name and password
I have not set any
Stu
you need to enter the login details for the machine the share is on (in the format MACHINENAME\USERNAME)
ie Iets say I have a machine called chuffbears, and I log onto it as Splash I would logon as chuffbears\Splash
