Network access to a scanner?
Hi folks
I have a HP PSC 1215 Multi Function Device which incorporates a printer and scanner - and I would like to be able to share access to both functions across my netowork, if at all possible?
Alternatively, I can buy a cheap USB or Parallel scanner to make available across the network...
Is the sharing of a scanner (other than a dedicated scanner) possible?
The clients accessing the scanner will all be running WIN XP Pro.
Cheers
zigzak
I'm not aware of any "consumer" scanner which supports sharing over a network. But perhaps someone else knows better??
Scanners like the HP Scanjet 7450C do support network scanning - but last time I checked the price of these scanners was something like £400 approx.
A scanner is not a sharable device so it cant be shared on a network. As zigzag says you can get very expensive ones that will do it but all normal home use one wont work in that way
