Network IP addressing crisis
Please help - I thought I had my network all sorted, but have unearthed a NAT mess!
My network is basically setup as follows
BT Voyager 205 eth modem
D-Link 634 wireless router
Server cl1 cl2 cl3
I am now trying to open up certain ports (Ie. Port 80 to the server, and Bittorrent ports to one of my clients) however I have hit a stumbling block with the NAT config. As it stands NAT seems to be turned on on the Modem (it says its on, and if I turn it off my internet connection on the clients dies). It gives me the option to setup virtual servers and DMZ or to turn NAT on/off.
On the router (which I want to use for NAT) I can setup virtual servers, DMZ and firewall rules.
Please can you advise me on how it should all be setup? As I can't make head nor tail of it all :? :?
Cheers
I cannot help personaly, but I use these sorces:
http://www.broadbandreports.com/forum/dlink
http://www.expansys.fi/forumoverviewcat.asp?man=D-LIN
almost everything has been asked at one time or another.
Simon
If you only have 1 ip address you have to run NAT. On the router simply forward the ports to the pc's which must have a fixed IP. So forward prot 80 to one pc's ip and the other ports to the P2P pc.
Note you can only forward ports to one pc
Thanks Smiley
TBH it's not really the router config that is giving me grief (port forwarding in the router is easy enough to do) its what I should have set up on the modem that is throwing me.... Do it have the nat on/off, do I use the DMZ, Do I need any of it on?
The links to the forums are great though, as they will help me with future router issues and the like. Thanks
on the modem set up a DMZ with the routers ip as the DMZ, that way the modem will forward all traffic to said router at which point you can start NAT etc
Cheers Mate.
I thought it maust be something like that, but when I tried the other night I kept messing up. I guess I was too tired. I will give it a shot later, and let you know if all is well!
Thanks again
All working fine now Cheesy
Thank you ever so much...
np Wink glad I could help.
