Network Drops During Sleep
Howdy,
I don't understand why, but my network connection seems to drop when I'm sleeping, or leave it for along time. I've gone through everything I can, my Internet connection stays active, I've changed my card settings so it stays perminanetly on and doesn't power save.
It requires me to restart my computer to fix the problem, I've tried it with firewalls on and off.
Could the connection firewall (in the connection settings be causing this?).
I'm out of ideas really
Have you set the card to wake up on lan? Does it stop even if you are using the network ie downloading?
It will be power setting of some sort its a matter of finding which one
I have no problems with the card, apart from it dropping during the night/day when I haven't been at it for awhile.
I'm not really sure why it has started doing this, it did it with my router too, but when I switched to my modem it stopped for awhile and now it's come back.
It seems to go dead when I leave P2P going, it did it while my Internet was active with me on it. It just cut out while I was playing a game, but worked fine on the other computer.
