Netscape 7.1
Netscape 7.1
Has anyone had trouble seting up netscape with mailboxs on Plusnet?
Netscape 7.1
Have you followed the instructions the PlusNet give in their help pages?
http://www.plus.net/supportpages.html?a=12
If you explain what problems you are having maybe we can help further.
SMTP
I'm having trouble sending to the SMTP server. What username should i use when i have mailbox's set up. Is it username+mailbox?
Netscape 7.1
SMTP requires no authentication when sending, It is only when collecting email from your POP3 mailboxes that you have to login. You just set your outgoing SMTP to relay.plus.net and don't set any authentication for it.
