Netgear icon
Netgear icon
Hi small problem but hope you can help. I have just installed my new netgear DG834G router modem after the last one failed.
However, I have noticed a problem when the install system places an icon on my desktop towards the end of the installation process. (The icon it places on my desktop is to enable me to access the router panel.)
The problem is its a generic icon and not the netgear cog icon that was there with the previous install. It works ok but where is the netgear icon and how to I change it.
Hope this makes sense.
1 REPLY
Netgear icon
Right click on the icon go-> properties -> change icon -> browse
There maybe an 'icon file' on your Netgear CD.
Not sure if this will work though, if not just use http://192.168.0.1 from your browser.
