Netgear Routers new firmware.
For anyone with Netgear Routers there is new firmware out.
DG834v3 latest is V4.01.20(UK)
DG834v2 latest is V3.01.31(UK)
iainmacmillan
Yes and the 834PN is also up to 1.03.30
Midville
Has anyone got this new firmware up and running before I upgrade mine - is it stable and working ok?
This would be mine DG834v2 latest is V3.01.31(UK)
Has anyone got this new firmware up and running - is it stable and working ok?
Yep did mine also v2 two days ago with no problems. Smiley
owlguard
I have got dg834gt modem router and i had to get onto netgear help line to set it up,just a few weeks ago,do you think there is the latest firmware with this and drivers with the w111t wireless usb.I would love to know but im scared to death messing with this setup at all.Can anyone help.Huh
regards ray.
Go into your router settings, 'Router Status' will tell you which firmware you have.
Check >>here<< to see if there are later versions and download if you need to update.
Midville
Thanks.... Cheesy
owlguard
Thanks for the help mate,regards ray.
