Netgear DG834G Wireless Indicator Light Blinks.
Pathfinder
If you have one of these routers could you confirm for me that the wirless indicator light on the front panel blinks?
I'm having problems with my activation the router is new and connected via ethernet (not set up wireless yet) and Im just trying to rule out problems. The manual says the light will either be on or off, not blinking? Is this just a mistake in the manual?
If it's not supposed to blink then maybe I have a problem.
I have the same router and mine also blinks when in use. I use it to connect wirelessly and through ethernet.
Have you updated to the latest firmware, that seems to solve a lot of problems.
Pathfinder
Thanks for the reply. Its looking like I either havent been activated yet (although I have had an emil to the contrary) or there is a fault with the line.
Cheers
Re: Netgear DG834G Wireless Indicator Light Blinks.
I also have the same model router. The lights have always blinked/flickered and it's been in use with no problems since January.
The power light is stable though, it's just the other three that blink.
TOTKO
I can concur. Only the power light is 'stable'.
I installed one yesterday - it went like a dream.
BTW is the upgrade necessary? Is it easy to do?
