Netgear DG834G Problems
Start IE, then select tools -> internet options -> connections tab.
Untick 'never dial a connection'.
Also click on LAN settings and make sure all tick boxes are unticked.
Can't help with the wireless side.
Hi i have just succesfully set up my router well according to the installation wizard i have..
But each time i open a new web page it still shows me as being disconnected from the internet and tries to log in with my old dial up connection..
Is there any way i can stop this??
and could someone please help me with setting up wireless internet access as i havent a clue where to start?
thanx a lot kyle
the internet connection problem seems to be solved now just the wireless now
This is not a silly reply but have you actually tried reading the manual or on-line help for both the router and your wireless card. They usually explain how to setup the wireless network. Look for an install CDROM for the router which contains the manual.
