Netgear 834
Netgear 834
Can anyone tell me the default port for web based administration of a Netgear834 router? Its my dads, I need to maker some changes remotely and he cant find the manual Sad
Many thanks,
James
Cloudmaster
Netgear 834
Have you tried the default port? e.g. http://192.168.0.1 (or whatever its IP address is)
Netgear 834
If you mean you want to make changes via the internet you wont be able to unless its set up in the router to allow it. Did you mean the port address or the IP. If its the ip ask you farther for his default gateway(start/run/cmd/ipconfig /all) the default gateway will be the ip of the router.
All router use port 80(wel 99.7%)
Netgear 834
Port 8080 as far as I can recall. But you have to tell the router it will be accessible from the Internet.
Netgear 834
Yes, it uses 8080 by default but you can change it to something else. You have to go into the remote managemanet screen of the router and enable it. You can then restrict access to a particular IP range (yours only I suggest) or to any ip address.
