Need help running ppt view direct fom webpage on a cd
I 'm looking to use powerpoint viewer on a cd but need to make it run and open the relevant file using just one click in order to make it work with as little user input as possable.
At present i have a link pointing to the exe file and when clicked it opens the open file dialouge box with the relevant ppt file listed. The user then has to click on the foile and open it from there.
What I'd like to do would have one link on the cd that runs the viewer with the relevant file automatically.
I'm using dreamweaver to make the cd but am happy to fiddle with code.
Cheers
A
if you open the show in powerpoint you can go to file and then package for cd and it will burn the presentation to a cd and will run automatically when you open the cd, you can also include other files and change some settings
I treid this but it dosn't want to play game. Autoplay opened and closed and presentation didn't run.
A
You should be able to load the presantation by doing
powerpoint myproject.pp
which should open the file ready you
