My router sucks
My router sucks
I can't get to the advanced options for my router.
Its a BT voyager 240 all i want to do is download properly so i want to set up a virtual server but i can't seem to get the settings to recognise my password. any tips?
Also any tips for setting up a virtual server any other way so that i can download faster?
MarkAngel
My router sucks
What does setting up a Virtual server have to do with your Router? I use Microsoft Virtual Server 2005 and you dont need to worry about Routers etc.
Why will a virtual server help with your downloads?
What is it you are trying to achieve?
My router sucks
I think, some routers use that term for Port Forwarding malynch.
Have you asked for help on http://forum.portforward.com/ ?
MarkAngel
My router sucks
Really...how bizzaire. Thanks for the update.
Mark
My router sucks
no you misunderstand me. i can't even get into the advanced options so i can't do what i want. any idea why?
My router sucks
Is it not under the "NAT" section ?
Wheelie
My router sucks
My neighbour had the same problem so we had to factory reset it and re-enter all his info, I also noticed that his firmware was old so got an update from here seems to have fixed the problem.
