My New PC Setup..
My New PC Setup..
Ok Just changed quite a lot of stuff. I made some mistakes earlier ( I need glasses )
Case
Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN)
http://www.overclockers.co.uk/acatalog/Antec_Cases.html
£81.08
Graphics Card
Sapphire ATI Radeon X800 GTO² 256MB DDR3 TV-Out/DVI (PCI-Express) - Retail (GX-101-SP)
http://www.overclockers.co.uk/acatalog/X800PCI_Series.html
£176.19
HD1
Western Digital Caviar Special Edition 80GB 800JD SATA 8MB Cache - OEM (HD-023-WD)
http://www.overclockers.co.uk/acatalog/westerndigital_sata.html
£41.07
HD2
Maxtor DiamondMax Plus 10 NCQ 200GB 6L200M0 SATA 8MB Cache - OEM (HD-027-MD)
http://www.overclockers.co.uk/acatalog/Maxtor2.html
£64.04
CD/DVD Drive
NEC ND3550A 16x DVD±RW Dual Layer Internal IDE (Black) - OEM
http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=9...
£28.93
RAM
OCZ Platinum EL Dual Channel Kit 2x512MB DDR400 PC3200 CL 2-2-2-5 Revision 2 (LIFETIME WARRANTY) (OCZ4001024ELDCPER2-K)
http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=6...
£133.57
Cooling
Zalman VF700-CU Quiet Copper VGA Cooler (HS-013-ZA)
http://www.overclockers.co.uk/acatalog/copy_of_Zalman.html
£23.44
Ebuyer Extra Value 120mm Internal Case Fan In Black
http://www.ebuyer.com/customer/products/index.html?rb=13788552640&action=c2hvd19wcm9kdWN0X292ZXJ2aWV...
£1.05
Ebuyer Extra Value 92mm Internal Cooling Fan In Black
http://www.ebuyer.com/customer/products/index.html?rb=13810600635&action=c2hvd19wcm9kdWN0X3Jldmlld3M...
£0.46
Ebuyer Extra Value 8cm Case Fan With Blue LED's
http://www.ebuyer.com/customer/products/index.html?rb=13810744563&action=c2hvd19wcm9kdWN0X292ZXJ2aWV...
£1.52
Processor
AMD (Venice) Athlon 64Bit 3200+ Socket 939pin 512k L2cache 90nm Retail Boxed Processor
http://www.ebuyer.com/customer/prod...oduct_uid=88109
£109.24
Motherboard
Asus A8N-E S939 nForce 4 ATX Sound Giga lan USB 2.0 FSB1000 SATA
http://www.ebuyer.com/customer/products/index.html?rb=13810461233&action=c2hvd19wcm9kdWN0X292ZXJ2aWV...
£62.59
TOTAL £723.18
Alecto
My New PC Setup..
Your hard disks are way too small. I'd get 600 to 800GB or you'll be running out.
My New PC Setup..
Hahaha
Moderators note by John (johnessex) full quote removed as per the Link:rules
My New PC Setup..
OOOooooooo You don't want to use that graphics card!!! <touches peak of flat cap in a knowitall way>
I just get a kick out of being slapped! Tongue Tongue
My New PC Setup..
I would recommend using a ASUS A8n -Sli mobo, that way if you do want to use 2 gfx cards in the future, you dont have to buy a new mobo. ebuyer do them at about £85.
I am using one at the mo, and not had a single problem yet, although I have only had it for about a week!
My New PC Setup..
indeed SLi it up, so that its future proof,. also get a larger disk than 80 lol. you will be surprised how fast they fill up... try to get an SATA300 disk , cos they are a lot nicer than anything else at the moment.. check tomshardware.com or bit-tech.net for some nice reviews of current gfx cards to see which would suit you the best
My New PC Setup..
Oh yeah, and I would get the 3500+ CPU as I think its only £7 more on ebuyer.
Not bad value for money considering the next jump up is about £30 more.
My New PC Setup..
I have 80GB drive for app's and games
and a 160GB for storing things
That is plently
and that graphics card is probably the best you can get for your money because you can unlock it to 16 pipelines, flash the bios http://www.techpowerup.com/articles//overclocking/vidcard/127/1
and then overclock a bit.
oh 2 graphics card might depends if I can muster up anymore money.
Re: My New PC Setup..
Do you recommend any changes?
Get 2GB of RAM instead, take a look at the Geil set ~ £135 or slightly better the Corsair twinx set ~ £180
See if you can find the X800 GTO2, it has the same core as the X850XT's and should clock well.
Change your DVDRW to a NEC ND4550, i have found Sony DVD's to be a little on the noisy side compared to others.
If you want 120mm fans try Akasa ambers, i think the ones you have selected will be very noisy
PSU - have you looked at the Hipers? They are very good. I recommend the 480w Type R Cool
I took your advice on the graphics card but im sticking with the 1GB corsair those are probably the best overclocking ram sticks on the market. i've seen people hit ddr600 speeds stable. average is around ddr550 at 2.5-3-3 or so. it'll overclock as high as the twinx stuff will.
My New PC Setup..
2 gig of slow ram is better than 1 gig of fast ram, but its up to you. check out the OCZ line of ram if you want to over clock stuff.
My New PC Setup..
Yes, i think you will regret not buying 2GB of RAM. Its a must for todays games like BF2 and Fear for an example.
holdtight
My New PC Setup..
Yes i agree with you paco2k5 i had the sony DVD-RW and it is a little noisy i changed it
for the NEC which is not only quieter but also much faster at spinning
up the disks than the sony too
I also use the Hiper 480w Type R PSU and its an absolute peach
i can highly recommend you use that one
Go for the 2gig of ram its a must and larger sata drives
My New PC Setup..
I can always buy more fast ram, and also I've heard there have been issues with having 2GB ram and BF2
My New PC Setup..
With the RAM, I did have just the 1gb, and BF2 was taking quite a while to load up when playing multiplayer, and it would take forever to stop stop stuttering when I first joined a game. I upped it to 1.5gb and it sorted out that issue instantly, now I can apply to be commander when the map first loads..woohoo!!
GET MORE RAM YOU WONT REGRET IT!
