Must have free util for rootkit
Some of the latest virus/spyware etc uses rootkit and this cant be picked up by any AV or spyware scanner. The only tool to check it in simple terms is
http://greatis.com/unhackme/download.htm
You can get a free copy which will test your pc. I would recomend everyone download this tool and test their pc.
Rootkit was used by our friend Sony so if you have had any cd near your pc you may be infected.
A more comprehensive tool is
http://www.sysinternals.com/utilities/rootkitrevealer.html
But its harder to understand the greatis one tells you simply you are clean or infected
