Mp3 player to stereo
i want to connect my mp3 player to my home stereo system, how would i do this?
1 REPLY
Do you mean the mp3 player software in your computer.
If so it depends on what audio card you have. Some have a line out as well as a speaker out and you would link this line out using a stereo cable to the line or auxiliary input of your stereo unit.
if you dont have the line out then you could use the speaker out but do make sure that the level is turned down using the sound card control panel on your pc.
