Mixed up keyboard
worcsdave
Mixed up keyboard
Since upgrading my computer and switching from Win98 to WinXP, some keys on my keyboard either no longer work, or only work when a different key is pressed (e.g. in order to type '@", i have to press the ' key!. Also, the pound sterling key no longer works at all. Can anyone suggest what might be causing this and any possible solutions? Cheers.
Mixed up keyboard
XP has probably just given you an American style keyboard layout. This can be fixed by going to Control Panel, Keyboard, Hardware Properties and selecting a UK keyboard.
Regards,
D'Essen
Cloudmaster
Mixed up keyboard
I think you just need to change your 'Regional & Language Options' in control panel
Mixed up keyboard
- Control Panel
- Select Regional Lang Options
- Select Lang Tab
- Select Details
You should see a US keyboard listed there, add a UK Keyboard and remove the US one.
Also ensure all the other options say UK as well.
worcsdave
Mixed up keyboard
Thanks gadget boy; that did the trick. Look - £££££ !
Cheers.
Mixed up keyboard
No worries, glad it worked out Cheesy
Aaron
