Minimise to Tray
craigbrass
Minimise to Tray
Hello,
Well this morning I was looking for a way to minimise programs like Windows Media Player so I could play music while working, also minimise FireFox windows to tray that I will be needing later. I found Actual Title Buttons. Downloaded the trial version and was so impressed with it I went to buy a serial number and was amazed to find it was only $20 (about £10). Anyway, this valuble tool can be found at http://www.actualtools.com/titlebuttons/
Nope, I don't work for em btw, was just very impressed with the software and thought I'd share it.
Best Regards,
Craig Brass
Minimise to Tray
dude this is just what i needed to put thunderbird into the systray (that is , ifi t works Wink downloading it right now)
//edit :
installed it, works great ^_^ got my thunderbird in the systray now hooza!
just one thing,. what do i get if i register it?
craigbrass
Minimise to Tray
It working for more than 30 days *winks*. Plus your supporting development, its only about £10.
Minimise to Tray
*bought it*
thanks man this is an awsome program ^_^
craigbrass
Minimise to Tray
No Problem, I always enjoy supporting inexpencive software developers, a way of supporting their good pricing.
Minimise to Tray
dude this is just what I needed to put thunderbird into the systray (that is , ifi t works Wink downloading it right now)
//edit :
No need to waste your cash if you just need to put thunderbird in the tray, check this link http://fileforum.betanews.com/detail/ThunderbirdTray/1097421396/1
Minimise to Tray
yea but its a cool app and its nice for other things as well Cheesy
craigbrass
Minimise to Tray
How is £10 wasting money? It's nowt really considering the software is cool!
Minimise to Tray
Its not the amount of money thats the waste, its the fact that you are spending money you don't need to that defines it as a waste.
If you can get something without spending anything, that does what you want, then by definition any amount of money that you spend is a waste.
If however by spending some money, you get more, or you get better, as long as the more, or better, is relevant then it could be worth it.
I agree that buying is better than stealing though, and we should all try and stamp out piracy.
