Microsoft cummulative security update (912812)
If you have downloaded the above update you will more than likely be having problems with "ACTIVEX" i.e. you will be getting a message "click to activate.
This is because of the following:-
http://www.betanews.com/article/Microsoft_Rolls_Out_IE6_ActiveX_Change/1141233576
If you want to fix it follow this link, or you can delete it and then stop it being downloaded next time you visit microsoft update site.
http://capitalhead.com/1239.aspx
