Microsoft Office 2000
I need to re-load my copy of Microsoft Office 2000 onto a new PC, but have stupidly lost the product key.
I vaguely recall there is a way of retrieving the key, can anybody help?
I have access to another PC running my copy of Office 2000 (same key used) or I have the disk available to me.
Help!!!
I'm fairly sure that if you run Belarc Advisor (from www.belarc.com) it will tell you the product key used for the installation.
painswck
Hi mariglenn,
You are right it does - and more.
Thanks had not come across that software before, very useful.
Roland
I think clicking on help and then about, normally displays the product key as well.
Aaron
Thanks guy's, your thoughts are much appreciated.
However, it is the serial number that appears in "about" not the product key unfortunately, the two are quite different.
And I'm sure the search programme works very well, but again unfortunately the PC with the working Office 2000 on it is no longer connectable to the internet, which makes that one a non-starter for me.
And finally, with the nagging feeling that I simply wouldn't have thrown something as important as that away (he said hopefully) I set about one last search through my increasingly untidy office...turned it over and gave it a good shake and eventually out it fell, and of course it had been right under my nose all along put away so carefully as I knew someday it would be needed.
So thanks again guy's
Pooks
Glad you found it. Office 2000 appears to be an anomoly in Microsoft's normal workings. Almost every other version of Office, Windows etc appear to be less picky about the way they store the product key and there is software that allows you to do it. AFAIK the only way to retrieve the Office 2000 key (without shaking your Office about) is to contact Microsoft with the serial number (and possibly a few other bits and pieces of info) who will then provide you with another.
Cheers,
Craig.
Cheer's Pooks...
Yes, your last suggestion occurred to me as well, however it would I think presume in the first place that one's copy of Office 2000 had been registered with Microsoft, and uhmm...
