Microfilters supplied?
Hi guys and gals, sorry if this message has already been posted...dont think it has....
Ive just ordered a Netgear ADSL wireless router to be delivered on the same day Plus.net kindly activate my broadband - does anyone know if this comes with a microfilter or will I have to buy one sperately from Plus.net or elsewhere?
Thanks in advance for your help,
Pete
Every router I have ever purchased (including several Netgear) has come with at least one microfilter.
If you only have one supplied you may need to use the test socket to eliminate extensions until you've had a chance to buy some more.
Ok, cheeers Lestones, appreciate the info!
I have purchased two Netgear DG834GT router from PC World recently, and both came with a single micro filter.
Chilly
