Memory problem
DerekB
Memory problem
I have 2 computers - one using as Asrock K7VT2 motherboard one using a ECS K7SOM+ motherboard.
I have just bought a 512meg PC2100R ECC memory chip and it won't work in either computer.
I have a non ECC 512 PC2100 chip which works in both.
I had thought that the ECC chip would work in most sytems - any helpful comments welcomed.
Derek
holdtight
Memory problem
ECC stands for error correction and these modules are typically used in Servers due to extra data bits and there reliability unless it otherwise states in your motherboard manual these are not compatible with your boards
It may be a good idea to go through the manuals to see what memory your boards take and if the module is new see if you can change it for non ecc unregistered memory
DerekB
Memory problem
Thanks Bill - neither manual nor the web sites mention whether ECC will or won't work - I guess I was just optimistic.
I bought from ebay so exchanging it isn't an option.
I'll have to find someone locally who can make sure it's not faulty then sell it on.
Derek
Memory problem
sell them on ebay again then ^_^
