Media Centre for Windows XP-Video card not found
I have installed windows XP pro with Media Centre on the PC that I built myself.
I have installed a Nebular Digital video card that works fine.
Problem is the Media Centre says: "No video card installed"
I have trawled though all the help pages etc to no avail. Can anyone help please or point me to a website or newsgroup that may help?
1 REPLY
Unless what your using is on the below list your going to have a very hard time running it:
Designed for Windows XP Media Center Edition 2005 Logo Partner List
Although here there is a link to some beta drivers that support MCE for your Video Card. But if you read below it you will see its not actually designed for all MCE's functions unfortunately Sad
I suggest you make any MCE/TV etc purchases from www.specialtech.co.uk as they are extremely knowledgeable in that area. They also have some excellent TV Cards and Cases and very informative descriptions that tell you whether or not you can use MCE with the gear involved or not. I own an Aver A16A and its great, unfortunately they are out of stock I think.
Good luck!
