Measure throughput between PC and router?
FooAtari
Does anyone know of a free tool than can measure throughput between PC and router?
If you use Windoze then TaskManager will give you throughput of your ethernet port by ticking the appropriate checkboxes.
FooAtari
Hmmm, which tick boxes is that then? Can't see anything at the moment but i'll have a hunt around google.
Netwroking tab then use View -> select Columns
or try netmeter which isn't mantained but is free and works fine http://readerror.gmxhome.de/
Windows task Manager > View > Select columns
Chilly
Doh!
Must type faster, or abuse my moderating privileges and remove post the pipped me! :lol:
Chilly
touch my post and you'll get your flippers slapped
You cant measure it as you cant send anything to the router which is what you are asking. If you send a 10 meg file to another pc and time it then that would tell you the spead from your pc to the router and then to the other pc.
The speed would be governed by how fast your disk could send the data, how long it takes for the AV to scan it. then how quick the data cant get to the router and other pc. In that would be cpu time Av scan on the receiving pc etc.
All network connection will be 100 meg less 20% QOS in xp plus any delay from cpu disk av.
FooAtari
Thanks for that.
Well I was able to stream a HD clip to the Xbox and copy a large file to another comp "pretty quickly" not exactly scientific but shows the equipment I bought does what I need it to do Cheesy
