MSN
MSN
Hi can anyone help, i have msn messenger and there is a facility for you to drag a pic into messenger and i goes straight away (live as it were), but alas not on mine, says my server may have blocked it, does anybody know how to cure this(apart from using aim instead.) steve
MSN
Are you behind a firewall? [software or hardware?].
Do you use a router? [If so: model and make?]
Which version of msn are you using?
MSN
norton 2003. modem router (etec) 4.7
MSN
Ok, I would either suggest using MSN 6.0 which apparently has support for NAT firewalls, etc.
If that fails, have a read of this.
MSN
thanks
MSN
To get this machine's MSN features to work, I just placed it in the DMZ Zone [all ports forward to me] and then ran ZoneAlarm firewall to block all ports except udp 5505-65505 [a huge security hole I know..but still! Smiley]
I would try the other options first though, as this is a highly stupid thing to do Smiley
