MSN Bug?
MSN Bug?
Hey all.
Just a quick question...I can send messages over msn and they show up on the other person's PC but when they reply or try to start a conversation it doesn't show up on mine. It only happens to this one guy but it's pretty annoying. I've also recently encountered a runtime error and the whole program shuts down. Any ideas would be appreciated Wink
MSN Bug?
what version are u running ( update to msn messenger 6.2 if not running that)
what kinda stuff are u runnin as well.. firewalls.. NAT Router?
Buz
MSN Bug?
I have 6.2, but all the problems seem to stem from this update. Before it was fine but since I have installed the latest version I'm getting all these errors. I've got the Zone Alarm Security Suite Firewall which I have given all the right permissions and just an ethernet modem.
MSN Bug?
I would try uninstalling ZA and see if that solves the problem, especially if your running V5 which has loads of issues and compatibility problems. If it makes no difference you can just install it again.
MSN Bug?
thanks, thats solved the problem Smiley
