MIDI question
MIDI question
Hi
Anyone happen to know off hand what i need to look for to connect a MIDI equiped music keyboard to a lap-top computer.The last time I needed to do this it was easy....... the Atari had a MIDI in out.But am lost on this one.
Ian & Linda Jordan (it's her fault I'm asking this question) :-)
MIDI question
The Midi port is generally part of the gameport. If your laptop does not have a gameport, you may not be able to connect a midi keyboard.
I don't think the USB to gameport adapters work with midi.
This link includes the pinouts for PC gameports/midi
http://www.electronic-engineering.ch/microchip/datasheets/pinout/pinout.html
MIDI question
Sigh!!!! oh well the only other option is to keep the laptop for myself,and buy her a second hand Atari :-) but thanks for the reply,although I don't think my soldering skills are quite up to the wiring diagrams you refered to.But I think I am going to have similar problems with my "Mac" so she can't use that......... Phew!!!
Ian & Linda Jordan
MIDI question
err... sorry sunhouse, you can actually buy a usb-to-midi adapter... such as theM-Audio USB Midi Interfaces
There have two single usb-midi devices, namely the USB Midisport UNO or USB Midisport 1x1
You can buy these products from online stores such as:
http://www.procass.co.uk
http://www.sub.co.uk
http://www.inta-audio.co.uk/
and the cheapest I've seen was at procass at 38.30 pounds... and it works with PC, Laptop and MAC.... Wink
MIDI question
Thanks mwong
A very neat solution,and have just put my order in for one,and I can "borrow" it for my Mac. :-)
Thanks again
Ian & Linda Jordan
MIDI question
Btw, be aware that you will also need some music software to record the MIDI input with - though I presume you knew that anyway! Smiley
Thomas
