MACs not showing in Router's set up
Scallywag
When I log in to my Linksys WAG-54G Wireless ADSL Gateway, and go to the "Show connected computers" section, there is never anything listed, despite there being 2 or more PCs or laptops accessing the router wirelessly at that moment. Any ideas why they are not appearing?
Thanks in advance for any help...
Are you using Static IP addresses or DHCP ?
On the D-Link router I have they only show up if you are using DHCP (on the router) to allocate addresses.
Chilly
Scallywag
I am indeed using static IPs not DHCP.
Interesting that this seems to affect it. Can't quite follow the logic. I want an easy way of noting down all the MACs so I can block access by any potential rogue devices. I suppose I'm just going to have to determine the MAC of each device individually.
I think Linksys has just dumbed down the name of the page.
It should be called DHCP status.
If your clients are Win2000 or XP then;
ipconfig /all
Will show there Mac addresses.
You should then be able to set up MAC address controls on your router so only your PC’s can connect.
Chilly
