Lost Outlook Express?
Del
:roll: Hi,
I have been using a beta version of office outlook express and decided to un-install it?
Unfortunately I must have un-installed the normal version of outlook express at the same time, does anybody know how I can either reinstall it or install outlook from new?
Downlaod the installer for Internet Explorer from the MS website, that should provide the ability to re-install it/
All the info is here
http://support.microsoft.com/default.aspx?scid=kb;[ln];318378
