Long name directories
zpeterk
Are the directories with long alpha numeric file names that seem to turn up after windows update OK to delete?
Where are they located?
If in temp folder then yes you can delete them.
zpeterk
They are in root, in them is a directory called sp2 which you can not look in
By root do you mean your C:\ folder? I would guess it relates to WinXP SP2 Beta, have you installed this? I haven't so con't confirm this.
If the SP2 folder is unreadable I suspect you can't delete it anyway.
zpeterk
They are in C:\ I haven't installed the beta SP2 only the ms updates
