Long Shutdown time on XP (SP1)
laurian
Does anyone have any good ideas/techniques for diagnosing the cause of long shutdown times in XP? It takes about 5-6 minutes to shutdown. It's a fully patched (with the excpetion of SP2!) and my only clue is that I installed "VideoStudio 8" from ULEAD and I think that it happened then. I remember emailing ULEAD on this but despite a few emails they never responded.
Any advice on this would be useful.
Thanks,
Ian Fidler
it could be that a service is hanging when you try to reboot. go to start -> run and type services.msc and disable the ones you do not need to see if this has an effect
buz
the_norris
Installing this util from Microsoft might help - User Profile Hive Cleanup Service
URL: http://www.microsoft.com/downloads/details.aspx?familyid=1b286e6d-8912-4e18-b570-42470e2f3582&displa...
Has helped in my case - also use it at work too.
Edit: TIP - best to use the MSI installer. Download and run like a normal EXE file.
You need to tweak the registry settings for:
"Hung Application Timeout"
"Wait to Kill Application Timeout"
"Wait to Kill Service Timeout"
Search for them in the registry and set the values to 1 sec, 1 sec and 2 secs respectively.
Alternatively download Cacheman XP and tweak it from there if you don't like editting the registry.
I think the values are in 1000ths of a second, so the values should be 1000, 1000 and 2000?Huh
holdtight
and its
"HungAppTimeout" and "Wait ToKillAppTimeout"
