Linux supported WiFi PC Card
Anybody got any recommendations for a PC Card (PCMCIA) wireless adaptor that has good linux driver support?
Cheers,
David
Try this list here
Atmel chip based wifi cards are OK, but look in /var/log/messages for the URL to download the firmware
Re: Linux supported WiFi PC Card
Depends if you want 802.11g compatibility. If you do, the atmel chipset ones work OK.
I have a Netgear WG511, but it only works using ndiswrapper to use the Windows drivers. You can't use kismet or airsnort if you do this, so I can't really recommend it.
If you're not bothered about 802.11g, try an Orinoco based card - these are cheap and plentiful and don't have compatibility issues for most people. They also have an external aerial connector. Also consider the Cisco Aironet 350's. They're good too.
Always look at the chip details. I have a cheap OEM Atmel based USB card running on my FreeBSD / Linux box no problems and no need for a driver wrapper. Had to download firmware stuff though but was simple.
Point is my rubbish no make card is the same as the Netgear card i also have and the only difference is price
