Linux on my box
jabb0
Linux on my box
Hey guys,
Just got Ubuntu up and running on my main machine.
I have even mamaged to get 2 ntfs drives mounted.
Howeveri have a few question i hope you can help out with.
1) I have got gnome running, and i need to find out how to burn a DVD?
2)Can i access a winxp machine to share files over a network? how?
3)is there a network neighbourhood avaialable, at least for Ubuntu machines on same network?
4)An mp3 player?
Linux on my box
For 3 use samba which should already be installed as it comes with most distros now.
I'm not sure I understand fully what you mean in 2. You can use samba to create network shares then access the shares on your winxp PC.
For DVD writing try some of these assuming you can get a version that installed on your distro or they may be installed already.
For MP3 players try here.
Or use google to find what you are after.
jabb0
Linux on my box
Doing a search on samba, i seem to have alot files to do with that program under my filesystem... how do i find out which one will run the program?
k3b was already installed, and it worked a treat.
Linux on my box
Samba is not a program it is a service.
Click on the samba link I gave and read the documentation. Your config files will probably be in /etc/samba. I don't know debian or your version (which is based on debian) so it may be different.
