Linux newbie guide
Linux newbie guide
After 7 years of supporting and using M$ based software, I'm starting to get my head around Linux (RH Fedora Core1). I can install it with no problem and set up users etc, but I'm struggling to get to my head round the more complicated stuff like setting up my PATHs etc and configuring Apache.
Can anyone recommend and good basic/intermediate guide as most of the HOW-TOs seem to assume that I know what I'm doing :lol:
michaelscott
Linux newbie guide
http://www.google.com/linux/
Although, I always found that the best way to learn was to play about, and if it broke, to fix it Smiley
Firejack
Linux newbie guide
Dead link Sad
Linux newbie guide
Oh I've already broken it loads of times :lol: I'm on my 3rd rebuild in 4 days! My main problem is not knowing how to fix the problems, for example, If I get a disk error under W32 I know what tools to use to fix it, but under Linux I've not got a clue.......
michaelscott
Linux newbie guide
http://www.google.com/linux (it doesn't like the trailing slash for some odd reason)
linuxnewbie.org
try linuxnewbie.org, the url below will take you straight to all the help you need -- including apache configuration
http://www.justlinux.com/nhf/intel/network/index.html
