Linux in a windows environment
Possibly a bit obscure but if anyone can help I'd be very grateful.
I have a windows 2003 server as PDC and I set it up as Windows 2000 Native in Active Directory. After many hours trying to connect an NT Server as BDC I found out I can't do so because I set it as Windows 2000 Native not mixed mode and the only way to change that is to reinstall Windows 2003.
Does anyone know differently or has anyone any knowledge of using Linux as a BDC to a Windows server?
Fixes: 5
Have a look at this. Not sure if it works with a Windows box as the PDC. You'd need to check it out properly.
Phil
Thanks for your help but it says that it doesn't work yet with NT PDCs
