Linksys Router BEFSR41
Will this Linksys Router work on ADSL networking setup
Comp is XP on both.
and both have NIC crds
Any help greatly appreciated
1 REPLY
If it's the one I think it is, It does not have an ADSL modem so it will not replace your USB modem. It is really designed for a cable modem to be connected to it.
For it to be used as a replacement, you need to purchase an Ethernet modem which will connect to the router. i.e. the D-Link 300G+
However, it is very expensive, and you can actually get a new 4 port ADSL modem/router for much less - i.e. the ORIGO ASR8400 for about £30 from ebuyer. Even a Netgear DG834 is cheaper.
