Line to Composite
craigbrass
Line to Composite
Hello,
I am looking for a connector that could convert a line out connection on a sound card into two composite connectors (red and white) that would then go into the back of a TV.
I am preferably looking to buy off eBay but have tried a few terms but can't find anything. Anyone know what I should be searching for?
Best Regards,
Craig Brass
Line to Composite
I belive so,
I got in comet to use with my Ipod, plug into heaphone socket, then into back of stereo, works a treat.
Edit just re-read your post proper, dunno about e-bay but try a google for tv cabling.
LiamM
Line to Composite
Try "3.5 to 2 phono".
I got this
Just what you need, but I'm guessing you don't want 5!
LiamM
Line to Composite
Hmm... This is a higher quality one.
Line to Composite
Get both then sell the five on individually :lol:
craigbrass
Line to Composite
I found this which adds to my earlier purchase of this perfectly. I was able to find it because of the help from Daniel so thanks m8!
Line to Composite
Liam was more helpfull than me he knew what the thing was callled!
craigbrass
Line to Composite
Yes, but I seen your post with http://www.tvcables.co.uk/images/thumb/pga3402_th.jpg in. I then searched for pga3402_th.jpg on google images and found the page it was on. I copied what they called it into ebay and hey presto!
