Keyboard prob's
Keyboard prob's
Hi
During repeated re-intalling of XP due to wireless problems ( don't ask ) i think that i have done something to my keyboard. When i type an email address the @ key shows up as " . To get the @ i have to press ".
Any ideas?
Oh, im using a laptop.
Gary
Keyboard prob's
I suspect you need to change your keyboard (and possibly language) to United Kingdom, the default I think is US.
Start-> control Panel -> Regional & language options icon -> Languages tab -> Details button and check you have United Kingdom as the default input language. If not select it from the drop down menu or add it using the add button.
Keyboard prob's
I HATE THAT!!!!
note : on installing XP you can remove the US keyboard layout by choosing to on the 1st pop up u get about language and region.. this will stop this happening within windows
its so annoying
Buz
Keyboard prob's
Hi
Thanks for the suggestions, but i already tried those things. Many thanks tho'
Gary
Keyboard prob's
What kind of keyboard does the device manager say you have?
Keyboard prob's
Hi
Device manager says:
"standard 101/102 - key or Microsoft Natural PS/2 Keyboard"
not very specific is it?
Thanks Gary
Keyboard prob's
Hi
Ive looked a bit deeper on my system and i can't find any other ref' to the keyboard. Strange.
Keyboard prob's
Try Start-> control Panel -> Regional & language options icon -> Regional Options ->
Mine is currently set to English (United Kingdom), yours might be set to English (United States)
Jeff
Keyboard prob's
Hi Jeff
Tried that but still getting " instead of @
I hate computers... were's my abacusHuh? lol
Keyboard prob's
Ok it was worth a try, I've got XP pro, it might be different to XP home.
Time for an email to Mr Microsoft I think.
Best Wishes
Jeff
An after thought!
how about checking in your autoexec.bat file (start > run > sysedit)
mine looks like this, but I'm not sure when autoexec.bat get's used.
keyb uk,,C:\WINDOWS\COMMAND\keyboard.sys
Keyboard prob's
Start>Settings>Control Panel>Regional & Language Options>Languages (tab)>Details>Add>Select English [United Kingdom] from drop down menu. Job done
Keyboard prob's
See my original reply - 2nd post - already been tried.
What may not have is in the same place as indicated above, remove all the setting/entries that are there and add them again and see if that helps. Yo may need a reboot after making a change.
Keyboard prob's
here should be a layout tab or something in the keyboard control panel.
on this there should be a button to add a new layout. add British layout.
make it default.
apply settings.
you may need to press left ctrl + left shift to change to the new layout.
once u have changed to British layout u can remove the US one.
(I am not near a windows pc to check what things are called, so i could have got names wrong)
Keyboard prob's
I have WinXP Home and don't see a keyboard layout tab/button or where it could be configured. Maybe you have a non-standard keyboard which required a driver or software to support it which has that option.
If you can get to look at an XP box, let us know where you saw this.
Keyboard prob's
i might be accessed form the regonal control panel.
on one of the tabs (i think the second form right) there should be a button to open the right widow, the button is called somthing like keyboard layout or advanced text.
