Joining .MPG files
Joining .MPG files
I sometimes get sent to me some mpg files which I need to join.
when they come in the format xxx-1.mpg I have no problem joining them
But I have some recently that come in the format xxx.mpg.001
can anyone tell me which joiner to use please.
Joining .MPG files
i've had best luck with tmpgenc (file>mpeg tools>merge and cut)
if you rename those mpeg files to 001.mpg etc do they still run?
Joining .MPG files
yes I did try renaming a few of them and they do run. thanks for reply
Joining .MPG files
and I tried the software mentioned above and it did not work with these files
Joining .MPG files
try dropping one of the files onto an application called Gspot (http://www.headbands.com/gspot/download.html)
this should tell you what codec the video is encoded as.
it may be that these are divx files renamed to mpeg.
Joining .MPG files
Have a look at the HJSplit web site for HJJoin.
