Java Failing to Load
Hello Everyone
When browsing my web (off line) some features do no appear. At the bottom of the screen I usually receive message saying "Loading Java applet failed" or "Applet fp hover not initiated". When browsing on-line all works OK. Can anyone suggest solution to this problem please.
Thanks for looking and for any help you can give
Tony Smith
its due to the fact that offline sites do not chache the java // server side scripting and thus will not work fully, there is no way around this i do not think
buz
Many thanks Buz
What I cannot understand is that all worked well until the past month or so. On my site I have features like hover buttons (links) which I now rarely see when browsing. This makes things very difficult when maintaining the site as I cannot test links. From what you say my best option would be to alter things around to eliminate items like hover buttons.
Thanks again for your help.
Tony Smith
maybe its cos ur PC updated to SP2 and withit a patch for IE that stoped this?
Thanks Buz
I'm not at all clear about SP2. I take XP updates but I dont recall having downloaded SP2, would it come automatically as an XP update?
I went on Microsoft tonight and updated PC but still no success in viewing the hover buttons when trying to Preview my Website.
Tony Smith
