Ione Gemini-M1 Keyboard & mouse
pimpernel
Connected this (cheapo) wireless PS2 set to computer running WinXP.
When computer first booted each day, the mouse works perfectly.
If I turn off during that day, even when unplugged from mains, then reboot the cursor refuses to move even though Windows tells me it is working OK.
When the mouse refuses to work, some of the icons on RHS of taskbar also fail to appear.
Next day just the same.
Have moved receiver, changed ID numerous times, changed batteries etc, but still unreliable.
Mouse also fails to work on different computer running XP Media Centre.
Keyboard works OK all the time.
Any ideas?
Sounds like a faulty mouse, contact the supplier and ask about RMA'ing the device(s).
pimpernel
Have contacted them to see if they know what the fault may be, also the manufacturer.
At least the fault is consistent - works OK after it is given an overnight rest, then fails to work after any reboots during the day. Strange!
