Internet Explorer 7 problem
foxwells
I start IE7 and it works ok for a while then it wont connect to any sites yet e-mail and Skype still work ok, only way out seems to restart PC, any ideas please?
glyndev
Basically having the same problem with IE6. It asks me if if I want to allow scripts to run. It will load the +net login page I enter username and password then nothing.
Netscape, Opera, Mail, FTP etc. are all OK.
The quick fix is either roll the pc back a few days if this has just happened.
With IE 6 got add remove and choose widows components and remove IE 6 reboot then install it again. with IE7 try add remove but it can be a pain.
You can try under tools internet option advanced doing a reset which may fix it as it gets rid of temp files and addons
