Internet Access from Office and Home
killban
Hi there all,
I have set my Father-in-law up with a Plus.net account for his home, so that he can finally have internet there. I have also just provided him with a laptop so that he can use it at his buisness and at home.
Now, the tricky part. At work, he has a Wanadoo dial-up connection which works fine with the laptop / intergrated modem. At home he will have, (tomorrow when I go round to install it for him), a Netgear Wireless Broadband Router for access to Plus.net on ADSL.
I am trying to figure out how to get Outlook / IE to dial-up at the office, and use the wireless at home. He is 70, so it has to be easy, or I will be getting lots of "Computer Helpline" calls.
Is this possible?
Thanks in advance.
Nicholas J Ball
If in IE you set the connection to dial only if there is no network you should get away with it tools/internet options/ conections.
These things have a habit of having bad days but it should work
killban
mwright,
Thanks for pointing me in the right direction.
I will take a look at that, and see how it goes.
Best regards,
Nicholas J Ball
