Install Binatone ADSL 500 in RH9 for newbies
I am a newbie to Linux, and have recently got hold of the linux drivers for the Binatone ADSL 500.
But I am having trouble installing it. The help file says to use the command
#rpm --rebuild USBENDPOINT-1.7-1.src.rpm
which doesn't work, because the rebuild command isn't detected. there is a rebuilddb command but the OS says that I have too much resources in use!
How do I install and set up the modem in Red Hat 9 considering I have the right drivers!
Linux Modem
Hi rolandbarzegar
Smiley Please post up the links, so we can download the driver and try it Cheesy
Here's the link, provided to me by plus.net
ftp://customer:binatone@80.176.199.241/ADSL500%20New%20Version/Linux/
roland
Doh!
It looks like this is for the new version of Binatone ADSL500.
Never mind, I will just have to buy that router.
Chilly
Redhat 9 and Binatone ADSL 500
I have installed the Binatone ADSL 500 driver onto my Redhat 9 installation and rebooted. At first it did not recognise the new firmware (even though I followed the instructions to the letter).
I found that I had to copy the new firmware from '/usr/local/e2' into '/etc' without renaming it to a mixture of upper and lowercase characters (despite the instructions saying it must be cnE2FHuh.bin). When I reboot now the boot messages indicate that the modem is recognised and loads with an [OK].
Where now? How do I set up the network connection using Linux? The redhat control panel displays an xDSL configuration page but only lists ethernet devices ....
Thanks in advance
Miles
hi guys i havn,t managed too get the adsl 500 running on fedora sad really
the file above just won,t open and just crashes my cd drive :roll:
