IRQL_NOT_LESS_OR_EQUAL Problems
Having major problems with the above message. It's getting more frequent. My PC just restarts for no reason. When I reconnect to the net my modem gets an error. I have to unplug it and restart it again. The blue screen message is ...
Stop:0x000000d1 (0x02bfe005,0x00000008,0x00000001,0x77f83scf)
Can anybody give me a helping hand how to get shot of this. Tried a windows dignostic test that came back all clear, so not sure what to do next.
Thanks in advance,
Damien
What windows verson are you using? Are you running with the lastest service pack and security updates?
That error can be caused by both hardware and software/driver issues and software/driver conflicts and is very difficult to identify the cause.
Try reinstalling your ADSL modem drivers.
I also suggest you go a google seatch on IRQL_NOT_LESS_OR_EQUAL to find some other suggestions.
Also check what temps your CPU is running at. Running to hot can sometimes cause this error to occur.
the_norris
There should be a bit more on the error message.
After the IRQL_NOT_LESS_OR_EQUAL , may be a device driver name etc.
This may give a clue to whats the cause.
Phil
